3.0L bogging around 1500-2k rpm
rbevis
97 3.0L Alpha II (sea ray 170)
Engine hesitates slightly in the 1500-2k rpm range. It runs excellent above this range and below at idle. If I slowly give it gas it is sometimes bad enough that it will attempt to die. Most of the time if I gun it, it will jump right past the stumble rpm range and be fine. Boat tops out at 40mph.
Things I've done so far:
- replaced fuel filters (at carb, inside mech. fuel pump, installed water seperator)
- verified timing in base mode (base @1dg. btdc, normal idle at 12dg btdc)
- replaced plugs (previous were @.050, new plugs are at .035) color on old plugs looked ok.
- replaced cap/rotor (previous had carbon buildup on points)
- tweaked mixture screw at base idle set in gear/in water (700rpm) It is approx 1.5turns out. (is there a way to vacuum set it? couldn't find a port) Mercarb.
- elec. choke is two notches to the right; however, it stays all the way open all the time. I'm assuming its because its so hot outside. Shouldn't be a factor.
- accelerator pump linkage is in middle setting
- compression is good on all 4 cylinders.
I did notice that when I gun it the accelerator pump will spray strong. If I throttle slowly the gas runs down the inside of the carb instead of shooting a weaker stream.
Is it time to rebuild the carb or is there something else I've missed? If I rebuild the carb I want to know that its the problem without a doubt.
Thanks.
Re: 3.0L bogging around 1500-2k rpm
Ayuh,.... try the other settings...
cr2k
Yes more volume and a marine carb should be set for most volume. If this doesn't help you probably need to rebuild carb. Need carb dip or spray and compressed air with small nozzle to blow out corrosion in passages. The check ball under the spring under the main jet nozzle assy may be corroded and sticking a little.
Could also be your advance weights in the distributor if you have points ign.
