3.0L mercruiser compression
Only if the fuel is properly stored and not contaminated, throw in some water and crud, then use it without filters and you will see !
Doesn't everyone throw water and crud in the tank to get more out next season ;)
Finz123
Fuel was from September I put stabilizer in it, but might pump it out and put fresh fuel in
When you see what is at the bottom of fuel tanks, especially the under ground commercial tanks where we get our fuel from, you might think so !
