3.0lx mercruiser pops and backfires through carb ????
SEARAY CHRIS
Hello,
I am new to the site and i need some help!!!I have a 1995 searay with the 3.0 lx motor that runs excellent ,,,,but when i stab it real quick it backfires and hesitates even with no load !!! I set the timing and even tried to give it a little advance but no luck !!! it has new plugs ,cap looks brand new , i have run a few tanks of gas through it but still happens!! Like i said it runs excellent when your going and doesnt backfire if the rpms are up and then stab it!! I have checked the accelerator pump in the carb when the engine was off and it seems to be working well !!! Any ideas???
Re: 3.0lx mercruiser pops and backfires through carb ????
Ayuh,... Welcome Aboard,...
It's goin' Lean...
It's probably crud inside the carb, a rebuild usually cures it...
Have ya checked, 'n changed the fuel Filters,..??
Volphin
Might adjust the idle mixture screws in a bit, but sounds like the carb.
V
SEARAY CHRIS
Well thank you!!
I have not checked the fuel filter yet but that is the next job, i pulled the throttle cable off the carb and sheared the bolt off the lever 52..00 to replace !! so im gonna order that part a new filter and base gasket all at once. next year i will rebuild or replace the carb!!! My buddy at the speed shop said it was going lean also !! Thank you very much
SEARAY CHRIS
Volphin i will check that also thanks !!!
