3.7L,470,4cyl:1987 Boat, can I use a 1984 outdrive
ta400man
I have the great 3.7L 170hp 4 banger... It is running great but my outdrive was not shifting properly. I attained a slightly older alpha one outdrive from 1984. I installed it and noticed that the discharge water was mainly coming from the right side and a little whole below the water intake. The 87 was discharging water from both side the same amount without the little whole discharge....
I want to make sure that the cooling water system is the same and I will not damage the motor with too little coolant water... I know the 470 are high risk motors for damage when they get hot so I am being careful...
Also do people think is too hot for the 470.... mine is running around 165F....
Thanks,
Shawn
jerryjerry05
Re: 3.7L,470,4cyl:1987 Boat, can I use a 1984 outdrive
There should be no difference in the drives the way they mount.If the motors are different then the gear ratio will be different.120hp verses a 165hp.Or a V-8 the ratios will be different but will work.The performance will be different.J
