3 part question concerning buying a 18' 96 mariah Shabah.
ninjamatt
I am giving a lot of thought to buying my first boat. I've read a lot on here about transom and stringer rot and decided to call a local surveyor to find out if he could inspect before I bought. He said he didn't inspect boats that small but He told me to call a particular shop near the Lake, near where the boat is. Anyway, the shop said all they could do was look at the motor and out drive for $75 bucks and said it would take about 5 days to get to, but mentioned a guy who repaired transoms and stringers for a living that I would have to call about that.
So I called him and he said he could look at it for free and it would take about 30 minutes. He also mentioned he's real busy this time of year. So my first question is, Can a guy who replaces transoms and stringers for a living tell me if there is any rot or is it possible it could be there and he not know, or could it be there and he say it's not for the sake of lying for future business? Also, what advantage does he have if he's so busy, spending 30 minutes inspecting a boat at no charge? It's not exactly like giving an estimate to repair a fender bender.
The second part of my question is; the mechanic shop I was referred to by the surveyor who stated they could look at the motor and out drive said it would cost about $75. Is it a wise investment for me to spend that before I buy a boat of this age? It's a 4.3 mercruiser. The reason I ask is that my dad has worked on car motors his entire life and owned a 73 caravelle for about 10 years back in the mid70s to 80's and did all the work on that him self. He will go look at it with me. His experience has been with OB's only though so I don't know if even if we take it to the lake for a test run, or look at it in the driveway, he has as much expertise as he thinks.
Lastly, the boat appears to be in good condition. I'm told there are no soft spots on the floor although the seat vinyl is cracked a moderate bit but the pics shows it's been stored in a carport. Is 6000 a decent price for this thing and does anyone have any opinions or experience with the quality of the 18 foot mariah shabah
Re: 3 part question concerning buying a 18' 96 mariah Shabah.
A fiberglass repair shop that will look at a boat for free will probably recommend some work. If you look yourself, you may be able to see if there are any problem areas.
I would definitely have the owner give you a trial run of the boat. That will tell a lot about the engine performance and if there are leaks, etc. check the oil level before and after the trial run to see if it changes, etc.
Anyone who has worked on automobile engines and outboard boat motors will do OK in looking at an I/O.
$6,000 would be OK for a price, $5,000 would be even better.
southkogs
You can "pre-guess" at the state of the transom, stringers and hull by lookin' her over real good by yourself first. Then if the shop says something you have an opinion pre-built to help judge. For example, stress the transom by really yankin' on it. If you see any flex at all, then you've got a problem of some sort. Walk the floor - if there's no soft spots, then you might well be okay. Get her nose way up and see if any water comes out. If it does, you might have a problem.
A good auto mechanic should be able to tell you if the engine seems solid. Outdrives kinda' work or don't (IMHO). If you can check the lube for water that would probably be good too.
I like tpenfield's thinkin' on price.
drrpm
The older Mariahs (pre 2002) had a good reputation as well built boats. I believe that they were wood free as well so rot shouldn't be a problem. If it was maintained it should be a decent boat. If it passes a sea trail and your dad's inspection I'd go for it.
