350 mercruiser 87 up
modsrx
I try to find a flywheel for a 87 mercruiser 350 sbc with a one peace seal .....does a flywheel from a manual car would fit ???
Yes, but look at trucks. Get correct diameter for the starter/flywheel housing
However what is wrong with your flywheel?
Only thing that can go wrong is the ring gear may need replacing
modsrx
Got abother motor to replace the bad one ...and its a 1 peace rear main ...flywheel and coupler are different
its a $70 cast iron manual clutch flywheel. stay away from the ultra-cheap chinese units.
