350MAG making hissing noise
billyman
I noticed yesterday my engine started making a "hissing" noise and after some inspection I think it's coming from the air intake.
Here's a video I shot. I can hear it clearly, but then again I know what my engine sounds like. Hopefully you guys can hear it and point me in the right direction. Thank you.
https://www.youtube.com/watch?v=PuP1FZ7ud8g
84EdH
Re: 350MAG making hissing noise
Billy, it is really tough to "here" noises from videos etc. That being said, it could be a vacuum leak. Culprit places are at base of intake manifold, base of carb, vacuum hoses etc. here's how to check. With the engine cold, squirt carb cleaner around these areas and listen for a change in the idle speed of the engine. A leak will suck in carb cleaner and change the idle for a few seconds. If you find a suspected spot, repeat to confirm......then fix it.
Walt T
Key word in his answer is COLD engine. Also make darn sure there are no stray sparks or be prepared to borrow the wife's eyebrow pencil
Hoosmatroos
I think it's the IAC (Intake Air Control) Muffler in the throttle body, the part no is 35-863829 cost you around $2, will fix your problem. Easy fix, you can do it yourself.
Fun Times
Most likely.
Not sure about the IAC . . . could be. . . but from the video, it also sounds like bearing noise :noidea:
As stated, it is fairly tough to tell from a video. You could listen through a tube to isolate the noise a bit better.
billyman
The foreign sound really sounds like it's coming from the air intake so my next step is to look for the IAC muffler, but thank you all for the suggestions. I'll report back w/ my findings.
billyman
I hope I'm not making a mistake reviving a 7 month old thread, but I wanted to confirm to all that suggested the AIC muffler (filter) was the issue, you were correct. $1.50 and the "hissing" noise is gone. It sure is nice when something is a cheap and simple fix.
Thank you and I hope this serves someone else in the future.
its your thread, you as the OP can revive it any time you want
