351w starter info/question
yonu
I need some info I am having some issues with my starter it tends to hang once the motor is warm when i attempt to restart it. I know it is a bad thing but I want to find out what is wrong this weekend so I want to go pickup an auto starter before I order a new marine one but I am not sure if I should get a starter for a manual transmission or for a automatic transmission. I am hoping someone may no.
Thanks,
Yonu
matt167
Re: 351w starter info/question
Just get a bendix kit and fix it. If your starter still turns the engine over fine, that's all you need. Bendix hanging on a Ford is sort of common
yonu
ok thanks should I then assume this is just from normal starter wear and rebuild it or is there anything else I should check as lwell since it is a 1974 engine it runs fine
sorry never had a starter hang on any of my ford cars they usually just quit completely on me
matt167
Nope, just the bendix kit is all you should need. It's probably worn or rusty. Pulling it apart and getting a good dry lube might even do the trick
The bendix can get sticky. It's not driven by a solenoid on that motor unless I'm mistaken. The cars/ trucks of that era did not anyway. If that shaft gets dirty or rusty, then it can stick either way.. I've had it happen to a few Ford vehicles and heard that is why Ford eventually fully adopted the starter mounted solenoids
yonu
ok thanks I will check around and see if anyone has a bendix kit in stock locally
