3M 5200 cure time??
KevinHall
Hey guys, I applied 3M 5200 4 days ago to seal up a few bolts on an aluminum hull. The stuff is still wet and gooey. Did I get a bad tube or this the norm?
DeepBlue2010
Try to spray a mist of water on it. Moisture will help curing. What temperature, humidity you got these days? Got pictures?
GA_Boater
5200 can be the messiest stuff used on a boat.
Letting it cure naturally can be as much as 7 days depending on temps and humidity, As DeepBlue said, water misting can speed the cure.
3M does have a fast cure mixture that cures in 24 hours.
sam am I
Fooooooooorever!!! Seems like 7 days is just not to be runny/gooey. More like a month to become even trimmable IME
Woodonglass
Yup it takes a LOOONG time but as everyone has stated It likes H[SUP]2[/SUP]0 so you really don't have to wait for it to cure. Use a razor blade and Acetone to clean it up and go Fishing!!!:joyous:
If you are worried about putting the boat in the water you are fine with 5200. I used it once when i drilled thru the floor while out for the weekend. Stayed there for the 3 years i owned that boat . If you want to clean up, acetone.
I have applied 5200 under the water line while in the water on a few occasions. great stuff, however is a moisture cure product. I prefer the fast cure because it doesnt ooze out as bad.
sublauxation
I've used it as a fast fix under the waterline while on the water as well. I'll get around to a more permanent fix some day but that was 5 or 6 years ago and it's still water tight.
fishin98
Look at your tube of 5200...sounds like you used the SLOW cure, which takes at least 7 days. I used it to seal the seams and screw holes on my boat. Wait a few days and you will be good to go.
KevinHall
Thanks for all the replies guys. I ended up going with the faster cure. The 5200 just wasn't setting up the way it said it would on the directions. It said 48 hours for tackiness to be gone, and 7 days full cure. After 7 days it was still just a gooey mess.
