4.3 belts,double to serpentine
cpt ron jc
i am in the process of doing a reman job,4.3 chevy v6, i would like to convert ,to serpentine,belt,instead of haveing the 2 belts,what do i need to change,pullys ect,what parts will i need,other than just the belt.
Re: 4.3 belts,double to serpentine
Ayuh,.... All you need besides the belt is the accessory pulleys, their bracketry, 'n the crank pulley....
It shouldn't run much over a Grand or two...
JustJason
There is so many nuts and bolts of it that add up very quickly when new. So much so that you may be better off finding a junk 4.3 that has the serpentine setup and then just strip what you need.
cpt ron jc
thanks i will stay with my v belt set up.
6meter
Good choice. Also with two belts would mean that everything won't line up.
