4.3 down on power
Stingray1961
This year took the boat out 1993 stingray 4.3 mercruiser boat struggled to plain rpm won't come up. Rebuilt carb fuel filter changed new plugs cap rotor timing checked . Good compression any suggestions
Need more info, what was it done during winterization and what was done to get it ready for this season?
Good compression, what were the numbers and when did you take them?
Stingray1961
150 this spring boat hasn't had the power it used to but this year it got worse. I winterize like I do every year fog it down do
Lower unit
Still know very little about the motor so lets start with fuel pressure, it should be between 4-7 psi from idle to WOT
