4.3 engine block plugs
smacks12
i have a 4.3 gl volvo, would it make any sense to put something in the place of the two drain plugs on the block for a quick winterizing and what could be used instead of plugs that could stay there. also is there any way to flush the motor without having to start it?
Alpheus
Re: 4.3 engine block plugs
You can use the plastic blue plugs that are used on some Mercruiser blocks, but I would stay away from using petcocks or hoses. You need to be able to put something (stiff wire) in the block when you winterize it to break up the deposits that form over the plug hole. Petcocks and hoses clog up and you run the risk of not getting all of the water out. The best thing to do is to Keep it simple.
Its always a good idea to run the engine on the muffs after each use, especially after salt water use. Running the engine washes away dirty water out of your water pump and thermostat...
Ayuh,... Ditto that,... Ya gotta be able to pick the Crud out of the passages....
