4.3 Marine to Auto Block Swap
Bondo, a 3/8" bolt screwed all the way in by hand, no extra effort needed. I did consider metric screws, but again with the ease that the 3/8" bolts went in, I stuck with them. Too late now for the oil pick up, pan is already on. In fact, entire engine is back in boat, assembled and ready to rock... Well, almost ready to rock. We dropped her in last night, it seemed to go well. Then all of a sudden we notice the bilge filling with oil. Quick inspection shows the pipe fitting for the oil drain broke at the block (I guess we bumped something). Luckily we were able to extract the broken fitting fairly easy and install a new one. That was problem 1. Problem 2 came whilst putting the sterndrive back on. We had a heck of a time keeping it in gear and aligned. Eventually got it, but anyone and everyone could tell it was our first time. Now it's time to fire up the engine. Hooked the battery up, checked all connections and turned the key. She cranked over a few times. Didn't start - no problem, probably waitin for fuel to make it to the carb. I go to turn the key again and all I get is a loud click. Damn slave solenoid is clicking its brains out. This is problem 3, which is still not solved. Solenoid is getting power, but when key is turned it drops to 0 V. Interestingly enough, jumping the solenoid causes the 50amp breaker to trip. Even with a non functioning slave, I thought jumping the terminals would still allow power to go through. Thus I'm not sure if the problem is the slave or elsewhere.
Ayuh,.... Chevy bell housin' bolts have Always been 3/8",....
The newest motors I believe are 10mm,....
zealer
Yes what you are saying makes sense. Perhaps the newer 01 block uses 10mm metric bolts and the older '97 block is 3/8. I never verified the precise size of the '01 block bolts, I just noticed they didn't fit. Anyway, concerning problem #2, no crank situation. I just came back from a week long vacation. I took the boat with me, hoping I could fix it there and get her in the water (cottage rental). The solenoid checked out to be fine. It was the starter, specifically the brushes, that were toast. Got that fixed, bolted the starter back on and voila, cranked over with ease. But now, she won't actually fire. More analysis shows absolutely no spark. Working my way through the Mercruiser flow chart, it will either be the ignition sensor or module that is causing the problem. I prefer if it is the sensor, cause I believe the module is $$.
zealer
Well I have some good news. It is likely that neither the ICM or distributor sensor are bad. No spark condition was due to yours truly incorrectly hooking the ICM back up. I had it plugged into the trim sensor!! I thought I went over the wiring a million times, but I just finally noticed it yesterday that the red/white green/white wires were not connected to the same color wires coming out of the distributor. I still didn't fire the engine yet. I ended up purchasing a new coil based on a friends recommendation (I trust him), but it isn't the right coil (needs external resistor). Unfortunately, my old coil was thrown out without my knowledge. I have to wait until Tuesday until I can get the right coil.
zealer
I couldn't wait to fire the engine, so I actually ran it yesterday with the other coil for a few minutes. She started right away, fast idled well enough. Still needs to be timed and low idle dialled in, but I was impressed. Showed good oil pressure at fast idle, at low idle the oil pressure would drop to 0 on gauge and buzzer would go off. Low idle was at 500 rpm, barely running. I'm surprised the motor even stayed running at that speed. Anyway, today I picked up the right coil, installed it. Started her up and now 0 oil pressure across the board. Gauge at 0, buzzer going the whole time. Don't understand this one, I'm actually quite annoyed. Feels as if I can't catch a break. Will test sender and grab a mechanical gauge to actually verify. I didn't hear any clacking from valve covers. Oil pump was working fine before the swap.
Fishermark
No oil pressure.... hopefully the pick up did not fall off. :( Get an oil priming tool and see if you can build oil pressure with that. (You will remove the distributor and install the tool and turn it with a 1/2 drill).
zealer
Hopefully it did not. Even to take the distributor out, I've got to lift the entire motor out. There isn't enough room under the fibreglass to pull the distributor up and out. I'll know for sure what needs to be done on Thursday, I'll have some time to do all the sender/switch tests and check the pressure mechanically.
zealer
The pickup in fact did not fall off. Rather, the distributor hold down was not tight enough, therefore the distributor rose up off the oil shaft a little bit, enough not to make contact with it. Live and learn! Everything is fixed, motor is in boat, properly timed and is running like a champ. Thanks all for the tips. Overall cost was $700 (engine, new gaskets, a couple tools, odds and ends, oil) plus my labor.
zealer
Forgot that I already updated the thread... oops!
