4.3 merc speed
sdw41lite
How fast does your 4.3 merc go. What kind of boat and what size prop
ewenm
Re: 4.3 merc speed
my two 4.3efi,s will push my 10,000 lb 32 foot mustang to a cruise of 26 mph at 3600 rpm 26 inch props on bravo twos
i think if you really need help/ advise you need to be more specific
90stingray
I have a Stingray 4.3 that moves to 42 mph with a 17p prop at 4800. My Glastron 4.3 goes 50+ (haven't had a chance to top out yet) swinging a 23p prop.
Each boat is going to be different even though they may have the same drive and motor combination. I looked at many boats newer or older, before I bought my glastron... all were 4.3 mercs and the advertised top mph's for each boat were all over the place.
Hope this helps you ...
Sent from my DROIDX using Tapatalk
sdw41lite
Re: 4.3 merc speed
I have a 96 monterey with a 4.3 alpha one gen2 with a 19 pitch prop goes mid to high 40s I just wanted to see what other boats are doing and with what size prop. Thanks hope more people reply
pat8839
Re: 4.3 merc speed
I have a Bayliner 195 with a 4.3 (MPI if it makes any difference) with my 19* 3 blade aluminum prop I can run up to 46.2mph GPS speed.
Re: 4.3 merc speed
The MerCrusier 4.3 with Alpha Drives had several different gear ratios. You might check to see which each had. it will make the comparison easier.
My '88 19' SR Sorrento 4.3LX went 42MPH with a 21 Pitch Rapture
sickwilly
Re: 4.3 merc speed
My carbureted 4.3 19 foot stingray hits 55 with a 23 pitch aluminum prop, and hits just shy of 50 with my 23 pitch stainless steel hi 5 prop. Its got a 1:81 gear ratio.
joewithaboat
Re: 4.3 merc speed
I have a 1996, 19 foot, caravelle 1900 se bowrider with a 4bl 4.3 that runs 50 mph gps@ 4800 rpm with a 19, ss, 3 blade mercury mirage. Doesn't seem to matter much 2 or 4 people, 4 just takes a little longer to get trimmed perfect allowing max rpm. Id like to try a new prop to get more top end but i don't think there is much left.
gunsup007
Re: 4.3 merc speed
Hey SDW,
Do you have a Manta Ray or like you said Monterey?
Just wondering because I have a 94 Manta Ray 203 Fish/Ski 4.3LX, alpha one gen2, 4 barrel carb., 19p prop and the two test runs I did (before I just recently tore down the engine to see why I was getting water in my oil) I was getting right around 47mph. at 4800rpm. My new engine will be supped up a little so I am expecting 50-55 mph.
sdw41lite
Re: 4.3 merc speed
Hi Gunsup, it a 1996 Monterey Montura 210 it has a 4.3lx with vortec heads and a 4 barrel webber carb. I have a 3blade 19 pitch alum prop. The gear ratio is 1:62 I think, not 100 per cent sure I just cant remember now
Shabah 182
Re: 4.3 merc speed
18 foot Mariah bowrider swinging a 19 pitch aluminum and tops at 48 running at 4800 rpms
sdw41lite
Re: 4.3 merc speed
anyone ever tried a 4blade prop on there 4.3 . I have been thinking about getting a mercury 4 blade alum 18 pitch prop
smokeonthewater
Re: 4.3 merc speed
You would do MUCH better to tell us what YOU have and what you hope to gain...... All this other stuff is just chit chat.... the fact that your motor is a 4.3 really doesn't mean it has anything in common with other boats just because they have 4.3's
Go look on the prop page at the "read this first" sticky and reply back with that info.... then we can get a mod to move this to the prop section and get you lined out.
sdw41lite
Re: 4.3 merc speed
I already told people what I have, get your facts rite before you make a comment, I am not trying to gain anything just asking other 4.3 owners how there boat runs. I dont know why this would bother you.
smokeonthewater
Re: 4.3 merc speed
Why don't you calm down a little... I wasn't bothered AT ALL and I didn't attack or insult you in any way.... I'm ONLY trying to help you get the best info possible.
It doesn't make much sense to change props if you don't want to gain anything and while you DID list your boat, to figure prop pitch you need rpm and exact speed.....
PrinceValium
Re: 4.3 merc speed
I have a 2011 Tahoe Q7i with the 4.3 MPI (220hp) Alpha 1, it has a 19P Mercury Enertia 3 blade stainless. The boat really has not been broken in fully yet however I did do a WOT run briefly and it registered 58 mph on the speedo trimmed up (can't remember the RPM I think it was at about 5000) This was with myself and two others in the boat.
I agree with Smoke however...all of us telling you what our boats do doesn't really mean much for yours. You should be telling us what YOURS does and what you have...and also go by the guidlines of WOT and what rpm you are at with your prop size.
gunsup007
Re: 4.3 merc speed
what did you do to the new engine
I am having it built by US Engine Inc. (www.usenginesinc.com) I ordered the supped up version. Supposedly it is bored out a little, they use a different cam. and I think they do some porting to make things flow better. They claim 50 more HP and I think like 27 torque, and 25% better fuel economy... We'll see. I'll let you know in a month or so when I get it back out on the water!
By the way I like the thread you started. I get your point, I was interested to see where everybody stood as well. Oh, and my gear ratio is 1:84.
smokeonthewater
Re: 4.3 merc speed
I had no problem with the thread at all.... just trying to help..... I'm not a mod and don't claim to be..... by all means carry on...
gunsup007
Re: 4.3 merc speed
Dang PrinceValium, you must have that thing waxed up! 58 is awesome! I hope my new one runs like that...
