4.3 MPI cooling diagram
SteveRay
Does anyone have a cooling diagram for 4.3MPI 2005 Merc?
Backflushing through the hoses with pink and can't seem to get the pink to come out the water intake on the Alpha leg....seems to be coming out somewhere else.....Just want peace of mind
4Winns2
Re: 4.3 MPI cooling diagram
On my 4.3 there is a hose that runs from the transom to the thermostat housing. Just track it from the transom down by the outdrive. It's true that on a back fill you should see pink running out of the leg onto your driveway. I usually take this hose off and blow through the hose at the thermostat housing to clear water. Here again though it should **** pink on the driveway when the block and passageways fills.
SteveRay
Mine is draining out on the driveway but I dont think its coming out of the water pickups.....The '05 has the 3-point drain system and I am also told I may have the cool fuel module as well....Maybe I just need to have someone watch while I backflush to tell me where its coming out.
4Winns2
You should see it coming out of either or both pick ups (they have little grills over them) beneath the cavitation plate. For piece of mind (something we all want when it comes to water freezing inside the engine and hoses), I would give a call to the local marina and just ask. Also, do you have a service manual that depicts laying it up for the season? Always a good tool for expensive toys.
jmarty10
Give mercury marine a call. They have answered a few of my questions
Ayuh,... Which Hose,..??
SteveRay
The hose that feeds into the T-stat housing.....on my old 3.0L it I used to fill the hose with pink and it would flow out of the water pick ups on the drive.
I think this is just because of the 3 point drain system flow diagram.....I just cant seem to follow the water intake line from the transom into the T-Stat.
