4.3 mpi
gergAlicious
So does the MPI indicate fuel injection? As is Multiport FI ? I thought I read somewhere that the 4.3MPI took special graphite embedded head gaskets, that you do not spray before installing. All others are sprayed (hi tack - or what ever is spec'd).
Does a carburetor engine really take a different gasket? My old gaskets were DEFINITELY graphite type, and mine is a 2bbl engine.
No difference on head gasket the base engine on both 2 bbl And mpi is exact same gm marine engine
if if you have a marine head Gasket set you’re good to go
porscheguy
Graphite gaskets are installed dry. Ribbed stainless gaskets get a very thin coat of quicksilver perfect seal on both sides of the gasket. This is per the mercruiser service manual.
thumpar
They have you covered on gasket info.
MPI is multiport fuel injection.
