4.3 riser cooling problems HELP
z284u2try
4.3 mercruiser 1998 18.5 bayliner alpha 1
I put a new engine water pump and 160 stat on this past weekend. Reason for this was the weep hole on the pump was leaking. The impeller is around 1 year old.
My driverside riser is getting hot but still be able to keep my hand on it. and my passenger side riser is staying very cool. I am guessing its time for new risers? I put the water hose on the hot riser water inlet and it flowed well is this normal?
I notice that this is a one piece riser and really don't see many of these.
My boat runs at 175 on the muffs with a 160 stat i think this is a bit high. Will it run even hotter under water load?
Re: 4.3 riser cooling problems HELP
Ayuh,....
It's quite Normal for 1 side to run warmer than the other......
z284u2try
Its hot like hell HOT. Uncomfortable to hold your hand on it. The other side is very cool like room temp. I will take your word for it.
Ayuh,......
Just the Fact that you Can put your hand On it tells Me,...
That it's probably Well Under 200?.........
brianvolt7
I had a similar problem with a Bluewater that had a 4.3. At idle it would heat up and when revved it cooled down. Boat shop told me to install a new impeller though I had just done it about two months before. I ended up taking their advice and it worked.
z284u2try
Ayuh it must be under 200.
Maybe I will try a new impeller first.
Thanks for the help guys.
