4.3 to 4.3 LX
Raypex
Can anyone tell me the "nuts and bolts" difference between a 4.3liter and the 4.3 LX engine? I know the horsepower rating is different, but what are the physical differences?
Just found out my block is cracked and I am looking for a new shortblock.
mrchev
Re: 4.3 to 4.3 LX
4.3l =2 barrel carb
4.3lx =4 barrel carb
not sure on intakes
im sure more knowledgeable people will post with more specs
Raypex
Re: 4.3 to 4.3 LX
Further research suggests that the only difference is the 4bbl. Thanks for the reply!
Raypex
Re: 4.3 to 4.3 LX
Does anyone know if the heads (ports) are different? Or is it just the Carb and intake?
By the way bond-o what is Ayuh mean? I am new here.
Re: 4.3 to 4.3 LX
Ayuh,... Google is yer friend, Try it...;)
sharkin95
Re: 4.3 to 4.3 LX
4.3 l has 2 brl carb vrs a 4 brl weber carb, the cam is the same 269 intake x 273 ex. valve lift is .394 in. x 404 ex. roller non adj lifters the heads are different, 1995 and prior 12 bolt castings were 10240209,10238181 1996 and after 8 bolt with larger intake and ex valves no crossover 4 angled bolts on each head.net h.p was betwwen 25-30 depending on what year.the older ones got 205 because no balance shaft and rochester 4brl carb. this engine is basically a v8 with only 6 cylinders. ....O KEE DOE KEY...
Raypex
Re: 4.3 to 4.3 LX
Thanks Sharkin95 and I must say for your first post, you came out big! My Head is spinning a little!
I'm not even sure what to do with these specs:confused:
My cracked engine is an '89 4.3 LX (205hp) and i am asking in case I find a good used 4.3(190hp)of the same year range. (I think '87 - '91) so I can possibly make it into a "LX"..
Raypex
Re: 4.3 to 4.3 LX
Don S,
Thanks for the cool link.
Bond-o,
I checked out Don S's link
Both you Guys,
I read a little and get that it means you're from the North-East but I honestly I don't think I understand it any better:redface:
My conclusion on the "Ayuh" thing is that I will learn to read past it! LOL
I asked because I thought maybe it was an Iboats forum acronym that long time users just get and newbies like me wonder about.
And again, Thanks to all for responses! Iboats and it's members are a real lifesaver!:)
