4.3L Carb Float height
dcf1999
Good Morning,
Does anyone know the correct float height for 4.3L mercarb?
TSB 97-8 (created June 1999) says 9/16 float level and 1 3/32 drop.
My service manual has same numbers in the spec part in the carb section BUT in the carb assembly section it gives a float level of 11/32 and drop of 15/16. The manual is dated November of 1999, so printed after the TSP? Is one a typo?
So which one is correct for the level and height?
I searched this forum and couldn’t find specific answer. I found an exact same situation, but it was for a TKS, which I don’t have, and didn’t know Id that mattered.
I attached pages as reference.
Thanks.
Fun Times
Seems some of it may depend on what design needle and seat your carb has and probably the year/serial number you have too.
Generally the service bulletin is more accurate when there’s a discrepancy in the manual.
By chance do you know where the setting measurement was when you opened it up for reference points?
Good Morning,
Thanks.
depends on if you have a spring loaded needle and seat or not
mikes is a good place for parts and rebuild kits if you need them
