4.3L upgrade to 350
dcpcccrc
Can this be done with the same outdrive i have been told yes as long as i change the pitch of my prop thanks in advance
phatmanmike
Re: 4.3L upgrade to 350
dont see why not, they both use the same bolt patterns in cars and such.... but what do i know.<br /><br />post this in the i/o section.... this section os more for fiberglassing and wood work
You really should be change the gears, that keeps you from having to go to something like a 28 or 30 inch pitch.
Realgun
The 4.3 is the same block as a 350 with 2 cylinders knocked off. :)
