4 select battery switch negative terminals
Am I correct in assuming I can just cable the negative terminals together in a 4 selector switch?
Have not seen a 4 selector switch, but if your taking about having 4 batterys and the only voltage being used is 12V, then agree
AShipShow
I'm assuming hes talking about a 4 POSITION selector switch for dual batteries (off/1/both/2)... Tho they usually don't have a negative terminal.. I'm assuming he means just commoning the negative terminals of the batteries themselves.
