429 ford inboard
jungnim2
Re: 429 ford inboard
motor is instalt by chris craft the me help
D
DJ
Guest
Chris stopped marinizing Ford's in the mid 70's. I'm not sure if you have a 429 or a 428 side oiler.<br /><br />You can id a side oiler by looking at the block just above the oil pan. If you see bolts going straight into the block perpendicular to the crank-it's a 428.<br /><br />The 429's were rarely marinized. Most marinizers used the 460.<br /><br />The 429 and 460 share nothing in common with the 428.<br /><br />If it is a side oiler it's worth some $$$ to a Cobra enthusiast. Probably not worth restoring for marine use unless you want to keep the boat absolutely original.<br /><br />Give me some #'s from the block and I'll see if any of them make sense.
bigblocksarefun
The 427 was used extensively by post and Chris Craft at least into the late 60's, maybe very very early 70's.
