454 Magnum ID tag
Bifflefan
Can anyone tell me or point me to a place to check what engine this is by the ID tag on the carb?
The tag says,
454 MAG B
7.4L SRX-H
1347-9863
The engine is NOT the same that the boat was born with. Per the casting numbers on the block its a
10237297...454..96-up...4-bolt, Vortec 7400", "L-29" Gen.VI, 1 piece rear seal
(bonus for me). I can NOT read (or find) any serial numbers on the block so without taking it apart I dont know what heads it has on it. Also seems these engines (except 96) had EFI of some sort and mine is carbed. I guess the intake could be from the old engine and maybe the carb is too. Any helpful info would be appreciated.
Thank you
no, there were both carbs and EFI for 1996-2000 7.4's
you wont know what heads you have until you pull your valve covers and look at the head casting number.
The 454 Mag had rectangular port heads
