470 Rocker covers all the same?
slydog75
Re: 470 Rocker covers all the same?
Bump for the morning crowd.
jerryjerry05
It should be the same.The people selling the part might send you a pic,ask them!!J
They are different. There are threaded bosses on the newer valve cover for cable attachements. There is even 2 different kinds in the 76 to 79 range.
slydog75
Thanks for the reply Don. I don't have any cables attached to mine at all (I assume something happened to the attachments when the previous owner had it). Do you know if that's the only difference? If so then it should work for me right? I'm having a heck of a time finding this cover and I'd be more than happy to have one that works fine even if I can't attach my cables to it.
stonyloam
They appear to be different, but the gasket part numbers (27-73666) and the cover part numbers are the same (41-638a1) are the same, so they should all fit. Mine is an 87 too and it does not have the boss for the cable anchor. You might drop a line to "Breezeworks", they have a lot of 470 stuff, or one of your local marinas might have an old one laying around for parts. Good luck.
slydog75
I'm still on my quest to find a replacement valve cover. I've located a source for Ford 460 valve covers. Does anyone know a reason that this SHOULDN'T work?
sdoomaha
Have you watched Ebay at all? That's where I picked one up for my 470. There's always 470 parts listed and there's a valve cover listed on there now.
Good Luck.
slydog75
Good Luck.
!!!!!!!!!!!!!!!! I LOVE YOU!
sdoomaha
Please tell me you are a single, 25 year old, 5'4", 105 lb, strawberry blonde, lingerie model, nymphomanic millionaire that likes middleaged bald fat guys. If so....I think I love you too!
I'm thinking that is probably not the case with a name like Adam however. : )
Kidding aside...hope the valve cover works out for you...take care.....
slydog75
Uhmm, let's see. That would be 0 for 9! Sorry!
alex3012red
I think my friend has one of a 85, let me know so I could ask him.
