5.0GLPEFS power valve size
jhamblett
Can't for the life of me figure out which power valve to use from holley rebuild kit. 2.5 or 4.5. I do not have a manifold pressure yet to divide by 2 to get close. Any insight?
Lou C
Take the build # off the air horn & look it up on Holley’s website
exactly. take the number and look it up in the Holley documents library. will also give you float setting, primary jets, squirter info, etc.
or look at your old power valve.
