5.7 gsi pwtr Timing shunt procedure contradictions
Leedanger
Hello all it’s been a long time.
Working on a 1999 Volvo penta Gsi PWTR TBI with a new long block in it. It’s been several years since I’ve had to set base timing on one of these and I’m reading conflicting procedures. Some say specifically to install the shunt and connect to 12v+ before starting the engine, some say shunt but do not connect 12v positive until engine is running (this is how I recall doing it), and I’ve even read it’s supposed to be hot swapped with the engine running which very much so doesn’t sound right.
When I first dropped the engine in I ran it with the engine harness plugged into the distributor to get it warmed up and it ran ok. I stopped the engine and installed the shunt, went to start it again and it blew out the starter almost immediately so I obviously f’d up something. If someone could please confirm what the latest procedure is for a sanity check that would be great! The part number to the shunt I’m using is 885163 pin A blank, B alligator clip, C & D are tied together.
Thanks as always
Leedanger
What do you mean by " blew out the starter "?
When I tried starting it with the shunt installed I believe it was too advanced and the engine rotated backward while the starter was engaged. This was far from a new starter so it didn’t take much but it does need to be replaced now because of it.
Leedanger
I’m trying to click on the sticky in the must read for delco EST in the Volvo penta section here: IMG_6338.jpegand when I do it takes me to some thread about an Evinrude outboard.IMG_6339.jpeg ?
I’ve tried using a different browser with the same result. Anyone have the most recent service bulletin for setting base timing on delco est using the timing shunt?
Lou C
Take a look at Michigan Motorz’s website, they sell a version of the EST ignition system and also have instruction on how to do that
Fun Times
I’m trying to click on the sticky in the must read for delco EST in the Volvo penta section here: View attachment 415353and when I do it takes me to some thread about an Evinrude outboard.View attachment 415354 ?
If desired, give that link in there another try as I was able to locate the tread in question online and then repaired (reedited) the link so it works now... Or here's a direct link too,
cobalt1999
Being this is a GSI and also applies to the GI, you do not use a shunt.
The computer controls the timing. To put the system in base timing mode you need to find the Data Link Connector located in front of the engine on top, it is inside a storage cap. You then jumper two terminals with a small paper clip (I don't remember which).
  • Like
Reactions: muc
muc
Thanks to @alldodge back in 2016. Note that you do this after engine is up to temp and running when you jumper.
Leedanger
Thank you. Now that I know better I’ve been doing some digging at it appears there still may be some conflicting info but this time it’s which pins to jumper. On this post it says B & C but on the image above it’s A & B.https://forums.iboats.com/threads/set-timing-5-7l-gsi.703924/
Any guidance on how I can clarify this for certain? Also worried that I damaged the ignition system using the shunt when I wasn’t supposed to have.
Fun Times
It’s A and B for sure…
Leedanger
Thank you for this. I have to admit I’m a little too dumb to fully follow the math he did to calculate where to place his 8 degree tape line. However, so long as the circumference of my balancer is the same as his I should be able to caliper the same distance eh?
In any event I should be able to resolve everything from here thanks again
