50hp 2 stroke center crank bearing
DeweyN
I have a 50hp yamaha 2 stroke with a press together crank and one of the center roller bearings have gone out. Is there an authorized or capable shop that can press it apart and install new roller bearings?
Bosunsmate
Re: 50hp 2 stroke center crank bearing
Those press ones are a real pain.
Try a motorcycle repair shop as its the same sort of cranks as those
99yam40
Will have to call around to find the right machine shop that has the jig for that motor crank and the know how.
If the bearing is bad I am sure the crank has been hurt also
