59 gale 35 hp, when pulled driveshaft, didnt see any o ring, did i ever have one?
35hpdan
hello, i just replaced my water pump impeller on my 1959 gale 35 hp, but i didn't see any o ring on the drive shaft near the power head, or a spot on the shaft that would support a o ring gasket, did it just fall off or maybe i never had one?
any ideas?
thanks
dan
Willyclay
Re: 59 gale 35 hp, when pulled driveshaft, didnt see any o ring, did i ever have one?
I believe it should have one but it probably "disappeared" sometime during the last 52 years! That's a harsh environment inside those exhaust housings. Try OEM p/n 303059, it should fit just below the splines and provide a seal between the crankshaft and driveshaft. Good luck!
Look at Item 27 on the gearcase page: http://www.marineengine.com/parts/v...evinrude-johnson/ITEM_2977/ITEM_297700001.htm
1946Zephyr
You'll definately want to get a new one in there. That o-ring helps keep the splines centered and also keeps lubricant up inside where the splines meet, so the drive shaft does sieze up inside the crank. I haven't had to deal with that ugly scenario, but several here have and it's not pretty.
steelespike
Also be sparing with the grease on the splines as too much won't allow the spline to slip into the craNK.
35hpdan
hello
does part # 303059 seal sound right? drive shaft to crank seal?
thanks
dan
35hpdan
hello, o ring in, fired up and all is good in the world!, next spring, see if the boat floats! lol
thank you for all your help
dan
Willyclay
Attaboy! Glad to help.
