60 HP SCOTT ATWATER DRIVE SHAFT
JIM MCCARTHY
I WOULD LIKE TO CONVERT MY 1958 60 HP SCOTT FROM AS LONG SHAFT TO A SHORT SHAFT AND UNDERSTAND THAT A DRIVE SHAFT FROM A 60 HP IS THE SAME PART AS THE DRIVE SHAFT THAT WAS USED ON THE 75 HP. IF THAT IS TRUE, IF I FIND A SHORT DRIVE SHAFT FROM A 75 HP, I SHOULD BE ABLE TO MAKE THE CONVERSION. I ASK BECAUSE THERE WERE A LOT MORE OF THE 75 HP ENGINES MADE THAN 60 HP AND IT WOULD BE MUCH EASIER TO FIND A 75 HP DRIVESHAFT. CAN ANYONE CONFIRM POSITIVELY WHETHER OR NOT THE 75 HP SHAFT WILL FIT?
THANK YOU,
JIM MCCARTHY
jbcurt00
Fellas, Please remember sales, trades, swaps & giveaways arent permitted in the open forum.
And @JIM MCCARTHY , why ALL THE YELLING?
