'63 28hp Rx-11
just_james
Is it possible to put a Pee indicator on this motor? And if so where would fitting best be installed?
Why? You can watch water come out the Exhaust Relief all Day long
+++---To the above tip.-----Not sure why folks are so paranoid about motor tell tales.------Just put a new impeller in every 5 years and go boating.-----A water pressure gauge at the helm station would make a lot more sense to me.
just_james
racerone, where would be the best area to drill/tap for a pressure gauge? I never thought about put one, just always went by tale tell. Also,where would be the place to drill/tap on 96 Evinrude 9.9? Thanks for this suggestion.
just_james
A 96 evinrude 9.9 will have a tell tale.-----Those 9.9 motors already had that " selling feature " in about 1978 model year.------Water pours out at the exhaust relief and is a tell tale.----Most folks do not look at tell tales nor do they realize that it is not an indicator of proper cooling !
The water pours out the exhaust relief on the 28 HP model.------That was good enuff back then.
