'69 Chry 55 hp water pump question
ruckerra36
OK, so this motor hasn't been ran for over 15 years. New points, plugs and impeller. But it doesn't spew water out the back, more like a mist at idle. Is this ok, $50 for the motor not bad I ran it for 30 minutes at an idle and it didn't blow up.
jerryjerry05
Re: '69 Chry 55 hp water pump question
Yes,it's ok.The water is exiting out the lower unit.J
