7.4 bravo II starting problem
captain zac
I will try to explain the problem if I leave out something please just ask the question and I will try to answer
1995 2855 w/ 7.4 Bravo II carb
When starting the motor it wants to kick into gear
If I push the button on the throttle to disengage the trans. so I can advance the throttle when the engine catches it wants to jump into gear.
This makes it very hard to start when it?s cold and its just not suppose to do that.
Not sure if it is something in the shifter or on the engine
The shifter is about 2 yrs old
About 6 months ago they had the engine out I watched them adjust the linkage using the manual and some sort of special tool.
Not sure if anyone can help but maybe this has happened to someone else
Please feel free to ask any questions because I am sure that I have left out something that could be important in determining the problem
To add I got the engine started yesterday after the temp. of the engine got to 145degrees I was able to rev the engine up and the problem went away
Harry
Re: 7.4 bravo II starting problem
It's possible that it's still out of adjustment. Maybe the cable from the engine to the drive is adjusted properly, but the cable from the engine to the control may be missadjusted.
I would disconnect the engine/helm cable at the engine and put the drive in neutral manually (with the engine at idle). Then see how the neutral from the helm matches up to the linkage.
You can download a copy of the OEM service manual at the link below. You need #11.
http://www-alt.mercurymarine.com/mnetdata/sisdata/srvcovr.pdf
Look at section 2A starting on page 34
captain zac
thanks
I will try it after dinner
the manuals would not download
can I find them somewhere else
Harry
It works for me, it's just over 11 MB in size, give it some time.
Might click here and see if you just download that particular section.
Any luck?
captain zac
Well
Yes and no
I followed your instructions and have pretty much determined with you help that it is the linkage to the Trans. ( I guess that is what you call it) ( the lower cable) After I made an adjustment to the cable the problem got better. But I like to make sure that I have done everything correct ( not confident ) so I hired our local
repair shop to come in and take a look at my work. ( in aviation we have one person do the work and someone else check it out) I explained what you had advised and he said that it sounded like that your advise had fixed the problem.
He will be looking at my work Tues. or Wed.
I will let you know the outcome.
I owe you one.
What size jacket do you wear?? I will send you one with our company logo
contact me at harry@bellaviation.com
Harry
Thanks for the offer Harry, but a jacket is not necessary.
Hope your adjustments work out for you.
Ayuh,.........
There ya Go Don,....... You just Blew your chance to be, Not only a Moderator,...........
But a Paid marine consultant here at iboats......
I gotta admit,......
Harry, that's the Most Generous offer I've Ever seen,........... Here or Anywhere else.........
I can't speak for Don, but I can for Myself,......
I love posting here because Motors,+ Wrenching is My forte,.....
Consequently,... I Usually get the answers Right.......
And,........
Just the Warm Feeling I get from a heart felt "Thank You" is More than enough for Me................
Harry,............
Feel free to hang around here at iboats for awhile, even though your headed to a Repaired boat,.......
Maybe some of the posters here can use Your Advise on Whatever......
We have more than just the I/O forums here......
Good Luck with the Boat,+ Welcome Aboard to the forums here at iboats.com........;)
