- Joined
- Mar 8, 2009
- Messages
- 44,096
Re: 7.4L- Should I bore it out??
I would call those valve spring cups, some have called them baskets. I don't see that style anymore, not that they are not still used. Do need a pic to advise on the location, but I'm thinking the slot would be for clearance to the opposing spring.
The pic part of iboats is working bad and the only which is working "sometimes" is the basic uploader. Select the icon to upload from "my computer", the box that appears locate the "basic uploader". This will change the view, then find the pic using the browse function, select "up load files". It can look like it is not doing a thing, and the button is not much of a button. Give it time and it should come back with the attach number
I am disassembling the heads but had a question. there is a "cage" for lack of a better term, around the springs. I was wondering if this had to be put back in the same position as it is now. I has a slot on one side, is the slot supposed to go in a particular direction. I know that is a terrible description, I tried to post a pic but am not having success.
