70 4 hp Evinrude recoil
twocyclemania
Just finished replacing the exhaust cover. I should have left the recoil and just loosened it a bit and slid the exhaust cover (if that's possible). Anyway I'm looking about 6 feet of unwound spring; the rest still there. A while back I did replace the cord without any problem as I didn't have to remove/loosen the recoil unit. Any advice on how to undue and do get it back on the motor. BTW - I hate recoils and never had good luck with them thanks
here is what I do... up to you
install the recoil with the spring hooked in but sticking the slot
manually wind the cord around the recoil then pull on it . The looseend of the spring will be sucked in the spring " chamber"
block the recoil
rewind the cord manually again then pull it out again this will further tension the spring inside the recoil spring chamber till it is all sucked in and hooks on the side port
when you feel you have enough tension to fully rewind the cord after you pull it out install the handle.
don'T forget that silly washer inside the recoil !!
done.!
or see video
twocyclemania
Thanks! I'll give it a try (probably more than one). I know exactly what you mean about the washer
block the recoil
done.!
or see video
Watched the whole video....yes, easy peasy! <Eyes rolling>
That gentleman has videos where he tries to remove the tapered dowel on OMC motors.-----Drives them in the wrong direction.-----For entertainment purposes only !!!
