'71 1350 fuel pump rebuild
Re: '71 1350 fuel pump rebuild
There are check valves in the pumps, along with those diaghrams. Inspect and clean them, and if that are bad, replace them. Yes, you will need two kits. I do not know the availability of the brass tipped fuel lines, so be careful not to break them.
