73 mercury 500 50 hp throttle issue
davidmerc50
i have a merc 500 i put new plugs in it new fuel pump kit rebuilt both carbs new inpeller and it runs good and idels good the only thing im have a issue with is when i go wot it bogs alittle and about 3/4 throttle the rpms build up and it will get on plane and everything but wot it will lose alittle power it acts like 3/4 throttle is better the wot any reason why this is doing that or should i not worry about it and its a tiller handle motor and the butterflys are opening all the way as they should help me please
Re: 73 mercury 500 50 hp throttle issue
Sounds like the bogging from idle is a carb mixture issue. Richen them a bit. The high speed issue is likely a fuel delivery issue. Maybe the antisiphon valve is clogged or a fuel filter is clogged? Air leaks in the fuel line?
davidmerc50
mine only has one screw and i adjusted them and no change and where is the antisiphon valve?
One screw on each carb? Antisiphon valve is usually inside hose barb on built-in fuel tank fuel pickup fitting.
davidmerc50
yes 1 screw each carb and ill check the valve and let you know thanks
davidmerc50
it has a external gas tank so will i still have that valve?
Portable 6 gal tanks do not have valve. Is vent open?
michaud500
I had the same issue. Check for air leaks!! Primer bulb!!!!!??
davidmerc50
Did yours run good at 3/4 throttle but not as good at full throttle?
davidmerc50
i did find that my clamp was bad on the connector hat gos to the motor would hat be enough to make it run like that?
michaud500
sure thing. Give a whirl post a report
davidmerc50
ok i tried out my boat with anew clamp still the same thing any other ideals?
oldman570
Have you replaced the fuel lines from the pump to the carbs ? They will go bad with age and the new enthol gas, and suck air or flak off on the inside and cause trouble. You might want to do a link and sync on the carbs and timming also.
Oldman570
davidmerc50
ok i havent check the hose but whats link and sync its in time and the butterflys open alike is there something diff. that needs to sync?
oldman570
New motors from the manufacture come with all the adjustable links set to the correct length needed for the best performance of the motor and should never be changed usually. The link and sync is the proccess done to get the carbs set to open up at the best time with the timming of the motor. A simple check of the setting is usally all that needs to be done anytime the carbs are worked on. JMO
Oldman570
