- Joined
- May 24, 2004
- Messages
- 14,289
Look at the size of the lower unit ----Now look at the size of the rear end on your pick-up truck.-----Outboard lower units are hard working items.-----Put in the best / recommended oil !!!
That really becomes apparent with the I/O gearcases, seeing much higher torque loads than the Outboard. My uncles OMC 800 series I/O kept shredding gear cases, upper and lower because his 'expert' friend convinced him the OMC oil was the same stuff as the cheapie 90w for cars/trucks found at K-Mart, just way overpriced. Once he started using the Hi-Vis he never had a failure again. Either the oil was a factor, or the repair shop finally got it right after 4 gear cases. Mind you an OMC 800 series was running on the edge when a 5.7(260hp) was attached to it, so the oil was critical with it.
