77 Skeeter Restoration
fishbone77
Re: 77 Skeeter Restoration
Got out this morning to start tabbing in the deck - there were a couple areas as shown in the pics where the gaps between the deck and the original fiberglass were too large for using PB - so I spanned it with 17oz cloth - These are not structural areas or areas that should have any real flex, but before I'm done, I'll probably end up double-layering them because the cloth is defining some corners, etc. This should also have pretty much sealed off the foam compartments - so I hopefully won't get foam spreading anywhere I don't want it!:eek:
fishbone77
Question time:
Until now, I've left the original holes in the hull from the transom mount bolts, the tie-down eyes, etc. I want to redrill these before repainting the hull - my plan is to drill an oversized hole, fill with PB, and then drill to size. My question is: is there any special type of bit that I should be using to not tear out the fiberglass? And any tips for keeping the holes square to the transom?
fishbone77
A good friend came over today to give me hand - got all the foaming done under the deck! Got a little carried away with the foam in a couple of spots, but it seemed to go well overall!
fishbone77
Got out for a little while today -
I cleaned up the foaming, and sanded down any excess foam and PB from the edges of the deck...
And I got the initial layer of tabbing done between the deck and the hull...
Woodonglass
You can build a Drill Bridge like this from a 2 x 6
and use a Spade Bit to drill your holes
or buy one of these...
jbcurt00
With an even larger sized hole drilled from the inside to lock the plug into the transom, & prevent the entire plug from being pulled out....
There's a pix of that @ here somewhere, I just can't seem to find it....
fishbone77
Thanks for the ideas - cheaper is better for me, so I think I'll opt for the 2x6 and the spade bit... thanks a lot WOG!
I see what you're saying jbcurt - makes a lot of sense - thanks for the tip!
Hopefully I'll have some time to get out tomorrow to put this to work! Thanks for the help guys!
fishbone77
Got out today and worked on the boat - I started building a drill bridge for drilling holes, just waiting on glue to dry...haha
I also put a second layer of tabbing between the transom and the hull, and between the deck and hull. I had a little extra epoxy mixed so I brushed some over the foam that had filled the pour holes in the deck to seal it.
fishbone77
Finished the drill bridge - Going to be able to drill holes in the transom tomorrow!
Unfortunately it looks like I'm going to have to make yet another order for epoxy:facepalm: Knew I should have just ordered more last time...haha
fishbone77
Got out and drilled the transom holes yesterday - I oversized them all and will be filling them with thickened epoxy tonight!
fishbone77
Got out this afternoon - used some thickened epoxy to fill the oversized holes in the transom. I just used masking tape on the exterior side to help hold the epoxy in - I didn't get it quite as thick as I would have liked because I ran out of cabosil, but it still held up pretty well... I also used a belt sander to sand the contour on to the top edge of the transom so it matched the original shape.
I also drilled new holes for the bow-eye, and refilled them with the same thickened epoxy.
Placing an order for some more epoxy today or tomorrow - I've used almost 5 gallons so far, I'm thinking I'll probably end up using 1-2 gallons more by the time the project's done.
fishbone77
Looks like the drill bridge worked well for you!
Sure did! Thanks a lot for the idea - it really made a difference, and kept the holes nice and square! Going back out today to drill the finish-sized holes and then hopefully some work on the cap!
fishbone77
Got out and sanded the epoxy plugs I put in the transom yesterday - after thinking about it, I decided to wait until tomorrow to re-drill the holes - probably unnecessary, but I want to make sure everything is fully cured.
Then I started sanding on the cap, but got rained out so I had to move the project back into the garage...So I broke out some of the Bondo-glass that I had picked up and started filling some of the extra holes that had been drilled into the cap over the years...
I also cut some plywood plugs for the cap where some deck lights had been before...
fishbone77
I also realized that I have some foam left after pouring underneath the deck, so I removed all the old foam from around the bow live-well, and cleaned the fiberglass - I'll flip the cap over and pour new foam around it for insulation before dropping the cap back on the boat.
geoff-nz
I'm really impressed with your perserverance and ability............awesome:)
Gator1996
Hey Fishbone. Just saw your thread and wanted to say that you are doing great work. Keep it up.
Good luck
fishbone77
Good luck
Thanks Gator! Will do!
fishbone77
Didn't get much time to work on the boat today - but I did get out long enough to drill the finish-size holes for the transom tie-down eyes and dry-fit them...I'll get out tomorrow to drill the rest of the holes tomorrow!
