'78 Ebko Lebaron - Therapy
  • Total voters
    13
  • Poll closed .
GT1000000
Re: '78 Ebko Lebaron - Therapy
Nice one...:eek::redface:
If you can still get them to screw in and out, with a little persuasion, they should be good to go...otherwise the push-in types or a rectangular opening would do the trick...
Another thought I just came up with...
You only need to be able to get on off, before you can take the the other one off...
You could make a shallow cut on the underside of one of the lids, and create a sort of hinged flap, that when you need to remove, you just lift and twist...
Kind of hard to make a clear sketch, but here's a try...
Trooper82
Hey GT..that is how I did it..and it worked great!...
Enjoy the 4th!!
Trooper82
Decided to take it easy tonight..only 6:00pm and the boat is put to bed....tools all put up...
I did clean the Deck off again...so neat to be able to say that :)
Oh ya....
I cut all the 6" and 8" tabbing...will put this on in the morning....hope I have enough resin...
Also had enough time to cut the 4 rolls of CSM needed to get 2 more layers on the deck...that was a lot of work....thank you wifey for the help !
Looks like my resources are getting thin!
Everyone have a safe and enjoyable Holiday!!!
GT1000000
Very cool...like they say awesome brains...:rolleyes:
Glad to see you getting ready for some deck tabbing and glassing...looking very good...
You and yours have a safe and fun Fourth!
CaptainKickback
Oh ya....
The last picture, I wander how many of us have a contraption just like yours. lol
Back to the access ports, I was worried that even though the flat areas line up OK, the curved portion prior to twist in would not let the lid go down. I guess you took care of that with the Trooper Flap. Or is it the GT Flap. Maybe the Trooper Flap GT model.
Have a great 4th.
Sea ya...
Decker83
Now that's funny Trooper Flap GT Model. :D
Man that is alot of glass to lay up. Start early and be fresh when all that goes down.
Looks good.
Trooper82
Looks good.
I only have the resin for the tabbing, plan on starting at daylight tomorrow.
That will be almost 5 gallons to lay the deck, yikes
jbcurt00
I think the admiral should have mandated a bedtime for you that more closely matched the tank painting crews. Daylight? I don't even like to stumble outside to let the new dog take a P at daylight. Let alone start glassing:facepalm: Probably why your tabbing in your deck & I'm still fighting the bedliner @ the tin & the cap is still 'on' the glasser that does not yet have a cradle.
Carp, you & Jas are machines..... Made me yawn just typing about it:eek::facepalm:
Hydrate & have a safe & fire free 4th:D
sphelps
Hope the tabbing goes well for you ! And hopefully the fiber glass back pocket pain goes away soon . Ya hate to blow the whole boat budget on stinky itchy stuff ya know !:D
Trooper82
Thanks sp. tell me about it. The wife looks at me like I am a nut when I say I need another 5 gals, maybe more.
Have a good 4th!
Colorado_Boater
Same for me thought we need 5 gallons, turned out we need a total of 15 gallons.
have a safe and enjoyable 4th
Thanks sp. tell me a out it. The wife looks at me like I am a nut when I say I need another 5 gals, maybe more.
Have a good 4th!
Trooper82
Ya CB I started with 15 gals. got 5 more...thinking I am going to need at least another 10 gals maybe more....
You have a good Holiday as well.....
Trooper82
Heading out to get the tabbing of the deck done....
sphelps
You too Troop ! Make sure ya keep the fireworks away from the acetone !:D
Trooper82
Tabbing complete!
SP - No fireworks near the boat, the acetone, the resin......period :)
jbcurt00
Apparently I mis-spoke. Your a highly trained, skilled machine:cool:
Now get out of the heat & celebrate pushing 1 step closer to done & afloat:D
Trooper82
Hey thanks JBC....Have a good Holiday yourself...
I was done by 9:00am and still managed to get soaking wet with sweat!
Trooper82
You dominate brutha Troop!
Thanks bear.......but not really, just a little double tabbing...have enough resin to maybe make some paste and fill the screw holes on the deck....I may go out and do that after the tabs dry...
Have a good Holiday !
