79 Chrysler 115 Won't go into gear
Walker2
1979 Chrysler 115 HP. I've seen some help on this on this forum but cant find. Wont go into forward or reverse. It tries but it makes noise like the gears wont fully engage.
Does the throttle handle move full forward and reverse?
Nordin
Does this happened suddenly, is it a new engine for you?
Does the remote cable for the shifting make the full stroke?
Maybe there is something wrong in the gear case.
Disconnect the remote cables and shift by hand a see if it make any different.
Noise? Like clack clack clack....?
These motors are either In Gear, or Out of Gear. They do not use a Friction Clutch, where there is Slippage, so NO Easing it into Gear. Try unhooking the Shift Cable, and Shifting it at the Motor, make sure the Engine is running, or have someone turning the Propshaft(make sure the Ignition is Off, better yet, unhook all the Plug Wires, and Ground them). There has to be rotating parts in the Lower Unit to prevent the Shift Linkage from being Damaged.
That Motor is over 45 yrs old, and maybe the Clutch Dog and the Gears are just worn to the Point where the Dog can't remain in gear under High Load.
Inspect gearcase oil .----Any water in oil ?---Remove lower unit.----Inspect spline at the top of the driveshaft.
Walker2
Yes, it does the clack thing like almost into gear both fwd and rev. I can put it into gear by hand both fwd and rev. It's like either worn out or not getting full stroke.
The Clacking Sound, is the Clutch Dog being 'Eased' into Gear. Causes Severe Wear on the Dog and Gears.
If it were mine, I would be opening the Gearcase up, and inspecting the Parts
jerryjerry05
Undo the shift cable and shift by hand and see if it works better? Possible bad shift cable or the shift shaft is corroded/corrosion and locks in place.
Walker2
Hi Jerry, After everyone's excellent help, I investigated all moving parts from controller to cable and linkage. (easy stuff first) found a loose locknut-bolt in one of the moving parts of the linkage. Seems to be working as it should now, Still have to test it in the water, but I think it's working.
Walker2
Thanks everyone. After everyone's excellent help, I investigated all moving parts from controller to cable and linkage. (easy stuff first) found a loose locknut-bolt in one of the moving parts of the linkage. Seems to be working as it should now, Still have to test it in the water, but I think it's working.
Thank you
