'79 merc 470 front motor mount, this doesn't look right....
montejw360
This is a set of pictures of the upper end of the front motor mount.
They show:
the adjusting bolt
adjusting bolt with sleeve
adjusting bolt with sleeve and fiber washer
steel washer on top of it all
the spacer is holding the steel washer up off of the fiber washer
and that doesn't look right to me. I just bought the upper washer and my parts manual shows the upper steel washer and lower steel washer having the same part number. So I'm wondering if the spacer is too long?
So, anyone out there really know this motor mount and what it's suppose to look like? The upper fiber washer looks like it's never had any pressure on it. I'm pretty sure this is how the motor mount was when I took it apart a couple years ago. The front of the engine would have to jump up in order for the upper fiber washer to do anything.
Thanks.
Bt Doctur
Re: '79 merc 470 front motor mount, this doesn't look right....
montejw360
Bt Doctur, I have the same exploded view. It doesn't show me clearly how the top washers and spacer are supposed to sit together.
thanks
Bt Doctur
the engine sits on the rubber mount pressed into #1, 17,18,14,19 go on top. Its to keep the motor from jumping off the top of the mount.
same principle for the rear setup. A washer and spacer above the mount to retain the rear of the motor should it somehow try to jump upward.
montejw360
Okay, so there is suppose to be a gap? If the engine does jump, it can jump up between 1/8" - 1/4". So it's just sitting there held down on the lower part by gravity? odd to say the least.
stonyloam
Where is the rubber mount? Isn't the spacer supposed to be in the rubber mount?
montejw360
The rubber mount is inside the post. The adjusting bolt goes through the rubber mount.
frantically relaxing
Your gap looks exactly the same as the thickness of your #14 washer, which you say is the same number as the bottom washer-- is the bottom #14 there? (just wondering!)
montejw360
Both washers are there.
stonyloam
Here is what mine looks like: Looks pretty much the same to me:confused: As far as I know it has never been touched (at least since "91")
Other than the fiber washer on Terry's looks like it may have swelled up a bit, they look pretty much the same.
