8.2 fresh water cooling
Status
Not open for further replies.
larson260
Can someone direct me to a cooling water diagram for the 8.0 cat engine. I'm trying to figure out if Mercruiser's newer unit is a full or half system.
This is a 4.3 but should be the same and all CAT motors are full systems
larson260
Thanks AllDodge. Are all new Volvo Penta engines set up with raw water cooled exhaust manifolds.
GA_Boater
V-P? You're asking about Mercruisers in the first post.
AD - That appears to be a V8.
VP systems are completely different plumbing than a Mercruiser. VP doesnt do 8.2s, their last BBC was the 8.1. Then they went LS 6.2
larson260
I will post it in V.P. forum. I'm trying to figure what my best option would be in my next cat stern drive other than having a large, expensive monster hanging off the stern of my boat when I back into a docking space for a weekend. Gang planks are not safe.
Yep, appears so
Your boat, but I wouldn't own a boat that requires CAT's, just way to much trouble. If this is a project boat you don't have to use CAT's, can install non-CAT and be legal
Lou C
Well I’d price out what it could cost to replace the cat converter exhaust if you are in salt water; Volvo parts could reach $6000 both sides and Merc $4500-$5000; in fresh water you may never need to replace any of it. Personally I’d never have one here (salt water 100%), if I really wanted another sterndrive boat I’d get the last year where cats were not required. Not ever going to get a boat where replacing the exhaust once costs as much as a new base GM Marine engine!
instead of a large expensive monster hanging off the boat (outboard) you will have a large expensive monster inside the boat (cat exhaust)
Lou C
If in freshwater I can understand not wanting outboards but in salt that is the way to go. Been doing this I/O maintenance a long time and don’t really want that again for my next boat.
muc
Not all MerCruiser cat motors are close cooled and not all MerCruiser close cooled motors are a full system. Depends on the model. When raw water goes thru the exhaust manifolds MerCruiser uses poppet valves to control temp.
Happen to have a open cooled diagram?
Status
