81 on an 85
seang
HI
i picked up a motor and outdrive complete from an 81 v6 3.8 will the outdrive work if i bolt it on to my 1985 intermediate housing.....i am concerned about the shift cables i know the mechanical shift cables are different than the ones on the 81 i Was told this unit was an 84 but on checking the serial numbers its an 81 and i Think i am stuck with it so can i use it or should i try and sell it
thanks
sean
Howard Sterndrive
there's no serial numbers on the lower unit, only the upper has numbers.
what you want to look for on the lower is a rectangular anode behind the 6 idle relief holes above the prop. Anode = 1982-1985 full mechanical shift.
No anode = 1979-1981 hydromechanical shift.
seang
I found that out the hard way purchased this 81 unit complete with motor the seller told me it was a 1984 but it is an 81
so I am stuck with it .....will this outdrive and shift cable work on my 84 ?
thanks for the reply
I do not think so. pretty sure you will have to sell your 81 and buy an 82-85 mechanical shift unit
