82' Evinrude 70 hp Fuel pump
Deuce22
Need to know how difficult it is to change the fuel pump? Just did a decarb and the engine quits when under a load. Mech. said it is most likely the fuel pump. Does anyone know the part # for the year and make? Any help would be appreciated!<br /><br />Thanks Again<br />Deuce
Re: 82' Evinrude 70 hp Fuel pump
Test it first. While moving under load pump your squeeze bulb...does the engine pick up speed? That would indicate a faulty fuel pump.<br /><br />The fuel pumps are easy re-build items however, it would be best to remove it and match the gaskets. Removal should take about 10 minutes (including break time).<br /><br />Bob
Deuce22
Bob, <br />Thanks alot, you've been a gret help!!<br />Happy boating!<br /><br />Deuce
