84 supra no go
Re: 84 supra no go
lol, thanks Bond-O. A little OT, but i was just looking at the intake manifold, and since the distr will be off soon, i was thinking of replacing the intake..(pics would show, its seen better days). The # on it 346250, but also, theres an "11" under those sets of numbers. I've tried xreferencing it, but only find the 346250 number with different # under it. Cant find any with the "11" under it. Will ANY #346250 intake work? Also, if so, will the Edelbrock 2101 Performer be a direct replacement...thanks again guys!
Ayuh,... Yer manifold appears to be a GM cast iron mid-rise 4bbl. intake,...
Any of the GM cast iron manifolds will fit it, so long as the Vintage is Right, as the intake bolt pattern changed in '86, then again in '96....
'n recheck the part number on the Carb yer lookin' at,...
I Believe the 14XX series are the Marine rated carbs,...
timmyboy76
Re: 84 supra no go
Bond-O, looks like my motor is 76-82, from what i've been finding. The intake on their now, looks lto have a few pinholes, thus, the reason for a new one. Found that the performer 2101 is a replacement. Not sure if i want to spend that kind of money or just find a 346250 replacement off fleebay for 75 buks. Also, when doing so, i read to install the FELPRO 1204 gaskets, since it cuts out the x-over exhaust, in which, since my carb..(edelbrock 1409) has the electric choke, that the new gaskets would help the carb benefit?
timmyboy76
Re: 84 supra no go
Guys...found a few 2101 manifolds. With the year of my motor, or what it looks to be, do i need the egr manifold or non-egr for my app? Thanks again...
Re: 84 supra no go
Ayuh,... Non-Egr, 'n ya don't need the heat cross-over either,...
salty87
Re: 84 supra no go
timmyboy...looks like you're getting great help already. if you want to chat with other fellow classic supra owners about anything else there's a supra site. it's the forum on supra boat's site. pm me if you can't find it. there are lots of 80's supra owners. i have an 87.
timmyboy76
Re: 84 supra no go
Hey salty! Yes, i'm getting help thats priceless..:thumb: I'll check it out. I'd like to know what TYPE of Supra i have..lol 84 w/Kevlar edition, open bow
Got the 2101 manifold yesterday. I know its been a few days of no progress, since i got the distr. kit. I figured, no sense diving into the dist, if i want to install a new manny. Anyhow, this weekend will be fun...:lie:
salty87
Re: 84 supra no go
it's probably called a Rider. a pre-cursor of the sunsport model.
good luck!
timmyboy76
Re: 84 supra no go
What up y'all...Its beenn awhile posting, but have yet to find the time, til yesterday! So, new manifold installed (2101), and voyager est installed, but think timing is wrong. Not ready to fire yet. Anyhow, my dilema is the wiring. From what i'm gathering, i dont have a neutral interrupt button/wire, anywhere. Reason being, when i removed the old distr, there's now only 2-wires to be used...purple and grey.
The EST, comes with a random set of wires/plugs..(i'll post pics later), but the "useable" ones go from coil to distr. The "set" plug to be wired to boat, from what i can see, are just the 2 plugs, one with a purple and grey wire off it, and the other, is either, a black wire with a white wire looped back into the connector OR a black wire with the white wires "cut" so close to the connector, theres NO WAY to crimp/use those cut wires....i'm thinking, the pur / grey wires go to MY pur / grey, and the other connector with black wire, just gets grounded.
