85 Johnson 70 question
burghangler
What size lifting ring do I use to pull this outboard? I'm seeing many listed on eBay, but not this year and size. Or what is an alternative to buying a lift ring?
Thanks
Re: 85 Johnson 70 question
The parts book shows a lifting bracket is on that motor between flywheel and cylinder head..----If it is missing you can likely make one.
