85hp acceleration
gussbuster
Hi, Im new to the forum and i have a 1989 85hp. When Im on the lake and accelerate from a stop, the engine will stutter for a few seconds before finally opening up to wide open. I have new plugs installed and wonder where i should look first. Any ideas would save me a lot of diag. Thanks!
Re: 85hp acceleration
Welcome to iboats gussbuster.
A 2 second stutter on initial acceleration is good for a 2 cycle motor.
It is a lag time for the fuel and timing advance to get synced up.
Stutter and acceleration- good, probably have the carbs running rich enough to provide adequate lubrication.
No stutter at all, carbs are too lean, motor not getting adequate fuel and lubrication.
A stumble and killed motor- carbs are way too lean, engine will die a grueling death.
If the stutter/hesitation happens further into the power band, you may have a problem, likely fuel related.
If the stutter lasts a long time and engine can't plane the boat, you need to look further into the problem.
gussbuster
Thanks roscoe!!
I didnt know a few second lag is normal, however, mine is more of a 5-8 second stutter...almost like its bogging a bit. Fuel is something I will definately have to take a look at. Has anyone had problems with fuel filter/diaphram? Could this be the culprit??
If the fuel pump diaphram was the culprit, the problem would get worse at full throttle.
Chances are you need to rebuild and adjust the carbs.
