86 110HP Regulator which one?
MallRat
I need to order a replacement stator for my 86 110hp Evinrude E110TLCDC engine.
I was told that it would also be best to replace the regulator at the same time.
Spoke to rep at CDI and he said to get part 193-4205 which is for Voltage Regulator 4 Cyl., 10 amp
CDI website said to get 193-4204 which is for Voltage Regulator 4/6 Cyl., 10 amp
Iboats parts lookup tells me to get this part number 0395204 which the CDI website crosses to this 193-5204 which is for Voltage Regulator 4/6 Cyl., 35 amp
So which one do I need?
MallRat
Thank you, Racerone.
The 193-4205 is straight on both the long sides.
The 193-4204 is curved on one side. I just checked the one currently on engine and it is also curved on one side. (don't think the 4205 will fit).
SO 193-4204 it is.
Your local Evinrude dealer will assist you in getting you the correct part !!
