'86 115 con rod bolt wrench
xmen3
9/32 too big 1/4 too small 7mm too big 6mm too small all six point.
What should I use?
JAG59
Re: '86 115 con rod bolt wrench
3/8 is larger than 9/32. Try to locate a 6.5 mm socket. Check both bolt heads to make sure they are not rounded off.
JUSTINTIME
it should be standard
look for a a 64th socket
Xmen3, If I remember correctly, I had a problem with this too. It was not the size of the wrench, but the thickness of the wrench, which did not allow it to fit properly. I ended up using a small 1/4" box wrench(12 point), which I needed to grind some metal off the "box" part, so it would fit between the bolt head and the rod.
