87 115hp - loose nut
rwilliek
While making a throttle cable adjustment, I accidently dropped the nut that attaches the cable to the control arm.
To make matters worse, it dropped below the power head.....how bad is this? Can I leave it or do I need to drop the lower unit to find it?
Thanks.
Robbie
79Merc80
Re: 87 115hp - loose nut
There is no way that nut can get below the powerhead. The lower cowling, there are 4 screws that hold it on.
rwilliek
Excellent - now do I need to fish it out of there or can it stay?
CharlieB
Do you have anothere SS nut?
Which is cheaper, a trip to go buy a SS nut, or a few minutes with a flashlight and a piece of coathanger wire to fish it out and reuse it?
Your choice.
rwilliek
I can't seem to find it....I did dig around with the magnet, only to realize that it wouldn't be attracted to the magnet - doh!
I will have to get the flashlight out..... my original question should have been worded Is it Safe to leave it in there...
Thanks
aussieflash
Try tilting motor up and down while someone listens for rattle,It may fall out.That's what I did.
Remove the 4 phillips screws in the lowest part of the cowling - where it says 115HP. The nut should fall out.
